I just installed Windows 7 on my SSD but my HDD doesn't come up in "My Computer". Did I not do something in the BIOS. Thanks in advance.
Make sure you format and partition the drive in the disk manager so you can properly use it with Windows.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496166
Right click to My Computer go to Manage
Click on Disk Management
then find the Partition that doesnt show up and right click
click on Change Drive Letter and Paths.
Click on Add and pick a letter
click ok
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496167
But it's not there so I can't right click on it.
does it say RAW or unformatted?
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496212
It says unallocated
you wanna create a new partition or recover the old one you had?
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496227
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496282
HDD probobly crapped itself outta jealousy now that SSD is the main man and let itself be slaved by crazy kittens from linuscattips :)
All kidding aside, you just need to create a new partrition (you probobly deleted partritions during installation) and you're good to go :)
+°´°+,¸¸,+°´°~ Glorious PC master gaming race :wub: ~°´°+,¸¸,+°´°+
BigBox: Asus P8Z77-V, 3570k, 8GB Ram, Intel 180GB & Sammy 750GB, HD4000, W7
PiBox: Rasberry Pi, BCM @ 1225Mhz ^_^ , 256MB Ram, 16GB Storage, pIO, Raspbian
https://linustechtips.com/topic/185625-ssd-and-hdd-help/#findComment-2496575
