So I have four Corsair static pressure fans and one air flow fan. I don't have a problem with them, I would just like to be able to control the RPM. Speed them up when I'm gaming, slow them down when I'm doing other things. All fans are connected to the fan headers on the motherboard. The four static pressure fans are 4 pin PWM and the one air flow fan is three pin. Two static pressure fans are connected via a fan splitter to the water block of my H100i. Corsair Link doesn't work so I can't use that for my fans. So, can someone recommend me a good fan controller? Also, I would probably need to get fan extension cables because I have the 750D and the fan cables barely reach the fan headers as it is.
https://linustechtips.com/topic/185298-fan-controller/
Have a look at Lamptron: http://www.lamptron.com/
I recommend the FC5 V3 but that's a personal preference thing so if you'd prefer a different one then by all means choose the one YOU like best.
As for extension cables... I haven't done much research in that area but NZXT has what looks like a good option: http://www.nzxt.com/product/detail/40-cb-3f-premium-cable.html
Here's the same thing on Amazon: http://www.amazon.com/NZXT-Technologies-CB-3F-Cable/dp/B0036ORCLW/
I hope that helps.
Resurrect the Mercury!!!!
https://linustechtips.com/topic/185298-fan-controller/#findComment-2496791
