Hey guys, so let me lay out the scenario. Our Modem is downstairs on the opposite end of the house, and i am upstairs opposite to the modem. So it is not inherrently easy for me to wire Cat-6 cable through my house. So what i'm wondering is, is there a way in which i can get an ethernet connection over to my room without running all the cable myself? and still maintain ethernet speeds and reliablility? Thanks :)
 CPU: AMD FX-6300     COOLER: Hyper 212 EVO    MOBO: ASUS M5A97 R2.0    RAM: Team Vulcan 8Gb (4Gb x 2) , G-Skill Sniper (4Gb x 2)    PSU: Rosewill HIVE-750w    GPU: ASUS HD 7790 2Gb OC    CASE: NZXT Phantom 410    STORAGE: WD Black 1Tb , Intel 530 120Gb     AUDIO: HyperX Cloud , Sennheiser HD 518 , Audio Technica ATH-M30 , Sennheiser MM30G , Yamaha RX-V361 , Pioneer SP-BS22     PHONE: Samsung Galaxy S7 Edge     PERIPHERALS: Razer BlackWidow Ultimate Classic , Logitech g502 ( Thanks Syntaxvgm <3 )
https://linustechtips.com/topic/184775-easiest-way-for-wired-connection/
Drill a giant ass hole straight through your house and get a 100 meter long Cat6 cable.
Seriously though, powerline adapter... I used one for a bit.
Build: CPU: Intel Core i5 4690k | CPU Cooler: Hyper 212 Evo | Motherboard: MSI Z97 Gaming 5 | RAM: 8GB G-Skill Ares 1600Mhz CL9 | Storage: 120GB Samsung 840 Evo + WD Blue 1TB 64MB Cache + Seagate Barracuda 2TB 64MB Cache | GPU: MSI GTX 960 | Case: Cooler Master Storm Enforcer | Power Supply: EVGA 600B Non-Modular |
What is a Powerline Adapter?
You could run a Ethernet cable to a downstairs wifi extender if your PC has a good wifi card. Or employ a sparky to route a cable through the floor and the walls (if you have the money and time)
Wifi card: http://www.newegg.com/global/au/Product/Product.aspx?Item=N82E16833166076
Powerline adapter
agreed^^^ i use it and will never go back
 CPU: Intel i5-4690K  COOLER: XSPC Raystorm 750 EX240 w/ Ice Dragon White Nanofluid MOBO: MSI Z97 GAMING 5   RAM: G.Skill Sniper 8gb 2X4gb 2133   PSU: Corsair GS800  GPU: SLI MSI TWIN FROZR GTX 760 4GB CASE: Phanteks Enthoo Luxe    STORAGE: SAMSUNG 840 EVO 128GB, WD BLACK 1TB, WD GREEN 1TB, SEAGATE BARRACUDA 1TB, WD BLUE 320GB KEYBOARD: Ducky Zero DK2108S MOUSE: Logitech G600
Its an adapter that plugs into the wall outlet and the other end is for an Ethernet cable to go in. Like an iPhone charger but for Ethernet cables.
Powerline adapter
So could you guys recommend any good Powerline Adapters for permanent use?
i have these
http://www.amazon.com/TRENDnet-Powerline-Nano-Adapter-TPL-406E2K/dp/B008F537KC/ref=sr_1_10?ie=UTF8&qid=1405994474&sr=8-10&keywords=powerline+ethernet+adapter
they are flawless. havent ran into any issues and i got them in october last year i also have two more in the house for other things
edit: keep in mind if you do use these do not run them through a surge protector strip they need to be plugged directly into a wall outlet
http://www.speedtest.net/my-result/3639699750
edit: i pay for 50 mbs dl
I pay for 25 mbs and this is my speed while watching youtube and playing counterstrike over wifi. http://www.speedtest.net/my-result/3639705308
And are there any problems i could run into or are there any things i should know about them before i go out and buy some?
As Bansh already mentioned, they need to be plugged DIRECTLY into the wall.
like i said only use them through an actual wall outlet other than that they are basically plug and play
hahaha got it
hahaha got it
and you will need two. you cant just buy one and plug it into the outlet by computer and expect to hop right on the internet. one needed for router and one for the device using the internet
http://www.galionsys.com/Manual/images/s1.gif
You can Use a Wifi device with your modem and computer if you have a strong Wifi card and devices. Wont effect the speed that much I guess. But you cant get the same speed as the main computer.
