Why no ground pin?
Go to solution Solved by squirrl,
All european plugs are like that aren't they? 2 pins.
Are you from the UK? If so, then that's not the right cord to use.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
https://linustechtips.com/topic/184447-why-no-ground-pin/#findComment-2478568
The metal strips at the top and bottom of the plug are ground.
CPU:Intel Xeon X5660 @ 4.2 GHz RAM:6x2 GB 1600MHz DDR3 MB:Asus P6T Deluxe GPU:Asus GTX 660 TI OC Cooler:Akasa Nero 3
SSD:OCZ Vertex 3 120 GB HDD:2x640 GB WD Black Fans:2xCorsair AF 120 PSU:Seasonic 450 W 80+ Case:Thermaltake Xaser VI MX OS:Windows 10
Speakers:Altec Lansing MX5021 Keyboard:Razer Blackwidow 2013 Mouse:Logitech MX Master Monitor:Dell U2412M Headphones: Logitech G430
Big thanks to Damikiller37 for making me an awesome Intel 4004 out of trixels!
https://linustechtips.com/topic/184447-why-no-ground-pin/#findComment-2478575
No,India.The plugs here seem to be a mix of european and british plugs.The pins are round and there is a pin on the plug for ground.
Why can't there be a standard plug for 220v and 110v....
https://linustechtips.com/topic/184447-why-no-ground-pin/#findComment-2478652
They are called Schuko, and not every european country uses them. Italy and Denmark doesn't.
Happy Danish outlet :)
NingoCase: NZXT H440 White, Motherboard: MSI MPower Z97, CPU: Intel 4790k, Cooler: Corsair H100i (2x Noctua NF-F12) GPU: MSI GTX 970, Memory: 12GB Kingston, SSD: Samsung EVO 120gb, HDD: Seagate Barracuda 2TB, PSU: evga 850 g3
https://linustechtips.com/topic/184447-why-no-ground-pin/#findComment-2478764
