Questions about AiO cooling the H440
Solved by Jodomcfrodo,
I would go with a NHD15 instead,
But if you must have an AIO, putting it at the front won't hurt your GPU temps much. I would personally put it at the top.
My personal opinion on CPU or GPU AIO's is that they aren't worth it. Either go air cooling on both or custom loop IMHO. GPU brackets have their issues and aren't worth it over air cooling and CPU AIO's are outperformed by the NHD15.
Now to the brackets (kind of jumping all over the place in this post):
The brackets for GPU's aren't great IMHO because they don't provide VRM cooling. It's better than air, but still not great.
Also, having 2 AIO's will make your system very loud. At the point of AIO cooling both your CPU and GPU, just go custom loop.
