I have the underscore as well, but mine boots? Have you the proper drive selected to boot into the OS?
ZEUS
CPUi7 4770K - 4.4Ghz CoolerNoctua NH-D14 MB: Maximus VI Hero RAM4 x 4GB Vengeance Pro DDR3 2133Mhz GPUWindforce 780ti Case: Corsair C70 Storage: 3 x 128GB 840 Pro SSD in RAID 0 , 2 x 1TB Barracuda PSU860W AX860i Displays: Asus VG248QE 144Hz , Asus VE247H 60Hz KeyboardRazer Blackwidow 2013 MouseRazer Deathadder SoundSennheiser HD 558 Mic: Blue Snowball
"If I'm not quoted I probably won't reply back to you."
when mine does this it's because I've physically changed around which hard drive was plugged into which sata port, you can either play around with plugging in your sata ports or try to change it in your bios, I say try because for me my bios just chooses say "nope, i cant see that hard drive that you clearly have plugged in, cant boot from something taht isn't there herp derp." so I have to change my sata ports, usually I have to run off of the CPU sata.
Why do you always die right after I fix you?
When you see the underscore, it's automatically entering a command to run your default operating system.
1. Do you have windows installed correctly?
2. Are you booting to the drive with windows on it by default (check bios boot priority)
3. Are you trying to dual boot?
