Graphics Card Advice
Go to solution Solved by GloriousPain,
Hey, wondering if anyone out there can give me some advice about what graphics card to get. I currently have an EVGA gtx 670 FTW 2gb and I'm looking to upgrade. I've got an FX6300 oc'd to 4ghz, can push it to 4.5ghz. I'm leaning towards an r9 290, but I'm not sure if my cpu could keep up with that card.
I'd Suggest just a R9 280(Non X to save money) and OC the card up to X standards maybe WC it, or CPU upgrade to 8320, or pocket the money you save... unless your playing at 1440 1600 or 2160p then get the 290...
https://linustechtips.com/topic/183718-graphics-card-advice/
Get a 280x
https://linustechtips.com/topic/183718-graphics-card-advice/#findComment-2468790
....270x would be worse than his current card....
Yea.. i edited it a second ago lol
https://linustechtips.com/topic/183718-graphics-card-advice/#findComment-2468804
5820k4Ghz/16GB(4x4)DDR4/MSI X99 SLI+/Corsair H105/R9 Fury X/Corsair RM1000i/128GB SM951/512GB 850Evo/1+2TB Seagate Barracudas
https://linustechtips.com/topic/183718-graphics-card-advice/#findComment-2468916
Lol nope
...yes he definitely would. Although I can see why he would want the new graphics card as it would give him more frames now, but a better cpu would balance out his build more, preparing him for the future. The 6300 is nothing special. An i3 will beat it in most games. There are some exceptions however.
I should be studying.
https://linustechtips.com/topic/183718-graphics-card-advice/#findComment-2471988
Yep, that depends if there is some special game out there that would happily support 6 "cores"
https://linustechtips.com/topic/183718-graphics-card-advice/#findComment-2515408
