Bios problem
Go to solution Solved by Jodomcfrodo,
You need to hit enter after entering the value.
I am trying to OC my FX8350 on ROG Crosshair V and when I set 'AI overclock tuner' to manual, I get the text boxes to start changing but it doesn't store the numbers I type...I'll put '24.0' or something into 'cpu ratio' and as soon as I click on another box, it immediately changes the box back to auto, its not holding what I type. It does that for all the boxes, even voltage and I changed it to manual. I tried clearing cmos and reseting factory defaults and I have the latest bios update.
Is my bois dead? or am I missing something? Does my board have dual bios and if so where is the switch?
The board works fine, no problems booting or running, but if i can't OC then what good is having ROG?
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/183166-bios-problem/
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/183166-bios-problem/#findComment-2462051
Duh!
Thanks man, it worked, you are a life saver!!
https://linustechtips.com/topic/183166-bios-problem/#findComment-2462065
Duh!
Haha, did the same thing a while back. I had changed stuff in the BIOS before, but that day I just couldn't remember to hit enter and started getting really pissed. Just laughed at myself afterwards.
https://linustechtips.com/topic/183166-bios-problem/#findComment-2462072
