Setting up SSD in existing system
Do you mean partitioning the existing drive to back up the files that are already on it, or the files in the ssd? The reason I mentioned that I don't have any spare drives is because I've seen some guides that tell me to reformat the old drive so windows will recognize both, so does that only apply to new builds, or will windows just know that both drives are there after I boot from the ssd for the first time?
Ps. Thank you for replying so quickly
You can partition the free space on your HDD to create another virtual unit (example D: ) All you have to do is back up your documents, pictures, music etc there.
Then you unplug the hard drive, plug in the SSD (that is empty) and make a fresh windows install there (you can use the same key, as the system is still the same).
Once it's done you can plug back the old hard drive, but remember to tell the Bios the SSD is the device to boot from. And delete the partition that has the OS installed (which used to be C: ).
You can add the free space on the hard drive to the partition that has all your data, so nothing gets wasted. Windows will register the storage partition and it will be available to use.
I use EASEUS Partition Master, it's free, works flawlessly and is pretty user friendly. If you are going to download it, do it from the EASEUS website.
