I'm a novice when it comes to OC so I just want to make sure I'm not overvolting and killing my CPU. I atempted a mild OC of my i5 3570K and I only changed the 'CPU Ratio' to 37 (3.7GHz) and 'CPU Core Voltage' to 1.045v. When the voltage was set to auto (before I changed it) it was running at 1.040v at default so I wanted to try and push an OC without changing voltage much. I ran prime95 and according to core temp it was no higher than 55 degrees on stress and 30-35 idle. Is this ok? Should I try to lower voltage and see if it can be stable at 1.040v?
Also I loaded the XMP Profile for my RAM to run at 1600MHz but should I also change the bios setting called 'DRAM Frequency' and set that to 1600MHz as well?
[Case] Phanteks Eclipse P400S TG (Air Mesh) || [CPU] Ryzen 7 5800X || [Cooler] Dark Rock Slim || [Mobo] ROG STRIX B550-F || [RAM] 32GB Trident Z RGB 3600MHz CL16
[GPU] XFX MERC319 Radeon RX 6950XT || [SSD] 1TB WD SN550 M.2 NVME || [HDD] 6TB Seagate IronWolf 7200 || [PSU] Corsair AX850
[Display] LG 27GL850 @ 2560x1440 - 144Hz || [Mouse] ROG Gladius II || [Keyboard] ROG Strix Flare (Cherry MX Red) || [Speakers] 2.1 Logitech Z-3 || [Fans] 6x 120mm Corsair LL RGB
Theater Room - My 11.1 Home Theater
https://linustechtips.com/topic/182674-voltage-question/
If 3.9 is all you want, then lower the voltage until it doesn't work any more. Then bump that up .01v. (just something I like to do to make sure.) If you XMP profile is set, you don't need to touch the DRAM frequency. If you want ALL DEM GHZ then put the voltage to a point where it is almost too hot and try to make the clock speed as high as you can.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/182674-voltage-question/#findComment-2455043
That's good.. I'd try pushing it farther rather than trying to lower voltages at the moment.
Maybe try ~4.4 Ghz @ ~1.200v?
I don't believe it really matters what DRAM freq is if its loaded the XMP profile correctly. I've done it both ways in my system and didn't notice a difference.
i7 not perfectly stable at 4.4.. #firstworldproblems
https://linustechtips.com/topic/182674-voltage-question/#findComment-2455062
