Hey, i am buying myself a new set of peripherals, i have already decided on the Ducky Shine 2 with blue switches. I am now struggling on choosing a mouse. I use a claw grip and game for hours on end so it will need to comfortable. I play RPGs and MMOs so macro buttons would be nice. I would also prefer wireless with charging (not batteries) but not too bothered if its wired. I play on a 22" 1080p monitor so do not need huge DPI. My price range is anything up to £100.
https://linustechtips.com/topic/18244-help-on-choosing-a-mouse/
For that many hours I'd do wired.  Lots a buttons....just go with your logo lol.  Go with M95 Mouse, I can definitely recommend that one.  I use an M65 but only because I don't need all the buttons the M95 comes with.
My Stuff:  Corsair Obisidan 550D - Phobya Nano-2G 120mm x 5 - Corsair H100i - MSI Z77A-GD65 Gaming - Intel 3570K - G.Skill 8GBx2 1866 - EVGA ACX GTX 780 3GB SuperClocked(Step Up to 780 Ti) - Samsung 840 500GB SSD - WD Black 1TB x 2 - LG Blu-ray - ASUS VG248QE + ASUS PB278Q - Corsair M65 with MM400 Pad - Ducky Shine II MX Brown with Gray/White Keycaps - Corsair K70 MX Red - CoolerMaster Quickfire TK MX Brown - Ducky Pro2 MX Blue with Gray PBT Keycaps - Ducky Pro2 MX Clears with Gray/Blue PBT Keycaps - Ducky Pro2 MX Browns with Light Gray and White PBT Keycaps
https://linustechtips.com/topic/18244-help-on-choosing-a-mouse/#findComment-212334
I use Logitech G9x. It doesn't really have a bunch of macros but it's a very popular mouse that I find awesome.
https://linustechtips.com/topic/18244-help-on-choosing-a-mouse/#findComment-212350
You have loads of different options.
Razer Naga is a nice small mouse which can be used in a claw grip with lots of buttons
Logitech G700(s) also a very nice mouse with lots of buttons, again quite small so good for claw grip and is also wireless.
Corsair Vengeance (any of them) also an option.
Logitech G9x, a popular choice among claw grippers
Theres loads more but dont need to list them :c
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/18244-help-on-choosing-a-mouse/#findComment-212364
The annoying thing is a few months ago i bought a Corsair M90 and its faulty but to rma it i would have to send it to USA and i live in the UK.
Definitely get something you can RMA locally unless the failure rate is super low like a Ducky Shine II keyboard, their stuff just works.  Rare is the case where I've heard of one RMA'd.
https://linustechtips.com/topic/18244-help-on-choosing-a-mouse/#findComment-212453
