Hello,
#1:
I have a FX 8320, with 2x7950, Asrock 970 Extreme 3 R2.0. I am a complete noobie at overclocking, and by guessing I got it to 4.5GHZ with a Be Quiet Shadow Rock 2 CPU Cooler and it goes up to 59C -+3C. So I'm worried that since I'm a noob I will lower the life span of my CPU by alot, so I ask here for advice. Is 1.4125V too much? I got it to work at 1.3875 (or something like that), it ran BF3 just fine at 60fps when I spawn and then I got ~90-110fps. But the problem is that in prime 95 It says illegal sumout on a couple of the cores. It still says that on 1.4125V but I just decided that it does not matter since BF3 works for me. I left the FSB on auto, the NB stock, and everything else on auto, because I had no idea what they did. Should I lower my Voltage to 1.3875 (I think it was that), change any of the other settings (FSB, NB, etc.) or keep it at this or even give it more power?
Please help me and tell me the best settings for me to run it at 4.5GHZ at the best settings.
Please note CPU and motherboard longevity is important for me as I do not wish to upgrade my PC for at least 5 years, that's why I did crossfire.
#2:
Also the reason I OC in the first place was because the FX 8320 bottlenecked my 2 cards and did not let them run at max usage, and I found that 4.5GHZ was the best and I don't need to push higher.
#3:
Does the FSB and PCI speed make my CPU communicate with my GPUs faster giving me more FPS and higher usage in games?
Thanks, and sorry for the long paragraph!
https://linustechtips.com/topic/182139-fx-8320-overclock-help/
overclocking on the Asrock 990FX extreme 3 with only 4+1 powerphase, and not the best quality vrm´s can be a bit tricky.
The core failures you get, can probably be related to your motherboard, which causing voltage throttle.
Its a well known issue with these boards if you trow a FX 8 core on it.
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2446972
Hello,
#1:
#2:
#3:
1.4V is at the point where you start to make a significant impact on the life of the CPU. Try to keep it under 1.4.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2446993
Dont OC on that board. It has almost no VRM cooling its only a 4+1 so you will get lots of Vdroop.
on another note I run my 8350 (higher binned 8320) @ 1.475v and have done for a year or so. people say its safe to 24/7 at 1.5v But jsut remember more voltage =  alot more heat.
Quack 🦆
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2446997
Oh its 970, and also can I fix this?
Thanks
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447038
I have to OC, because it bottlenecks my GPUs if I don't. So that's why I'm asking for the best way to do it.
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447055
Okay, how can I check if the voltage is enough.
Lower it, then stress test with AIDA 64 or Prime95 for a few hours.
My Setup:
Desktop
Main Laptop:
Thinkpad T420:
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447060
1.4V is nothing for an AMD CPU.
But the problem that "op" has, is most likely related to his motherboard.
like i said above ;)
Can I fix that Motherboard problem, because in games like BF3, I get all the cores working it just seems to be prime 95...
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447067
Thanks
Ah you right its the 970 extreme 3, but its also the same story.
Can you fix it? well i think the only way to fix, is buying a decent motherboard.
like the Asus M5A99FX pro R2.0
You could offcourse try to trow a fan towards the vreg, but i think it would still thorttle.
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447136
Where is the vreg. I tried AIDA 64  and it said hardware fail, test stopped! Why is this my CPU temp was 60C?
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447153
no my 8320 is 1.4125v stock
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2447240
It's at 1.4V at  4.5GHZ But I have issues, I'm afraid that it will break. Is this true?
the volts are fine so yes it wont break
My Setup :P
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2452521
The problem seems to be the motherboard when it comes to OC stability. If it's bottlenecking in games I'd just sell it in a bundle and move to... alternative platforms rather than throw money at it.
But good AMD boards are:
  • M5A99FX Pro r2.0
  • 990FX-UD3 Rev4
  • 990FX Sabretooth
You should be able to get a lower OC with less volts, try 4.3ghz @ 1.35v
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2452654
With amd I think you mean around 1.5vcore
CPU: Intel Core i7 4790k CPU Cooler: Corsair H100i Chassis/Case: Fractal Design Arc Midi R2  Motherboard: Asus Z87-Deluxe RAM:  Team Vulcan 2x4Gb(2133Mhz)  Video Card: Asus 7970 Direct CU II Custom Rom (150% Power, 1100 core 6Ghz Memory)  Power Supply: Fractal Integra R2 750 Watt  Keyboard: Cooler Master Quick Fire Rapid (MX Blue Switches)  MouseCorsair M90 Storage: SX900 128Gb, Seagate 1TB 7200RPM, WD Green 1TB 7200RPM   MY OLD BUILDLOG
The Fastest 8350 @5.33Ghz with a score of 9.16pts in Cinebench 11.5
https://linustechtips.com/topic/182139-fx-8320-overclock-help/#findComment-2452700
