Hey LTT,
I remember making a thread about this a while ago, but can't seem to find it in my history, so I've assumed that I posted it somewhere else, or no where at all. If I have posted this before, I apologize. Since I still don't know the answer and I think I posted the question somewhere else, I'm hoping you guys can help. (I couldn't find a better way to word that, sorry.)
But now to my question. When adding voltage to a GPU, is there anything to worry about besides VRM and GPU temperature? Also what temperature is safe for GPU VRMs? I'm asking this because I want to go farther on my overclock but am worried about putting more than 1.3v through my GPU. When I have 1.3v going through my GPU, the VRMs reach about 50c and the GPU reaches about 40c. This is also with a 130% power limit. Would there be any chance of breaking my GPU if I went to 1.4 or even 1.5v?
Thanks!
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/182059-vrm-temps/
don worry it can handle 50 no problem even 60 70 80 mine goes over 95
Should I be worried about anything else besides temperatures while overvolting? Could anything break from too much voltage even if it is adequately cooled?
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445817
Hey LTT,
Thanks!
Your GPU can only handle a Voltage to a certain point with it starting to damage the card permanently.I mean I have 1.35V and 450W going through my GTX 770 and its on air but I max out around 77-80C in games or benching. But I suggest you hope over to the 780ti owners club on overclock.net to get some more help on the issue.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445819
1.35v on air and 80c? Wow that's impressive. Would you happen to know why it would do damage if temperature is fine? The bios I have allows 1.5v.
I'll be sure to hop over there and ask. Maybe that's where I asked before. I'll check.
Thanks!
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445843
Thanks!
Because the voltage regulator will actually start burning out at such a high voltage, and it starts to degrade quicker (just like mining does to AMD gpu's).
Thank you my GTX 770 is my best overclocking card I have owned to date.
|King Of The Lost|
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445858
My card hit 82c at stock and 1150mhz. What clock do you boost to on stock?
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445860
My GTX 770 stock speeds boost to 1245mhz but overclocked I boost to 1780mhz and hit 78C (Average) (Note I have 2 Noctua NF-P12's running fresh cold air to it also)
|King Of The Lost|
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2445872
?? 450w... how did you come up with that?
Modded my GPU's Bios and changed the TDP (Kepler BIOS Tweaker)
|King Of The Lost|
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446102
1780Mhz??  World record on air over here?  How do you measure your power draw and boost core clock..
5820K - ASUS X99-A - 16GB Corsair LPX - HD 7970 GHz - Qnix 1440p @ 96Hz - Waiting for Polaris/Pascal
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446103
Just because you used Kepler bios tweaker and change the TDP threshold doesn't mean your card is using 450watts...
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446110
@VSG can help with this hopefully. He can explain better than I do, also about the 450w gtx 770 thing, your air cooler can't keep up with 450w of tdp, thats waterblock+ln2 territory.
My 780's at 1.325v barely managed to hit around the 350w range per card.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446111
GPU-Z and you can't really measure Power-draw straight from the GPU itself but my total system Power draw is 650W+ and that is due to my GPU, (Plus its not a world record if its a Boost speed, in my book)
|King Of The Lost|
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446121
How are you measuring your power draw? 650 Watts from an air cooled GTX 770 and a overclocked 4770K ... I'm not buying it.   Also, you must have messed up your bios, because you are not hitting a boost clock of 1700Mhz. Not trying to be a dick.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446151
If he hit 450w on his 770 at 1.35v, that must of meant my 1.325v on my 780's pulling 350 was actually 700 watts per card! lel.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446170
Exactly. I have pulled around 500 watts from my Lightning alone @ 1.5v @ 1529Mhz on the core. That was measured from my entire system consumption with a Killawatt meter from the wall and then applied PSU efficiency. The power draw would have been lower if I could have kept my card colder, but I would only image 50-65 watts at the most.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446171
Exactly. I have pulled around 500 watts from my Lightning alone @ 1.5v @ 1529Mhz on the core. That was measured with a Killawatt meter from the wall and then applied PSU efficiency. The power draw would have been lower if I could have kept my card colder, but I would only image 50-65 watts at the most.
I didn't measure mine with a kill-a-watt, I went around checking all the bios mod threads on OCN and other places, and looked at what others kill-a-watt readings were for their titans/780's, and did my best to guesstimate.
I also figured that since my PSU fan actually turned on for once when I was benching them with a 5ghz 3930k that my calculations were pretty dam close lol (my PSU is 100% passive until it hits 45c, regardless of load)
First time I've ever actually seen it turn on lol
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446182
1780 MHz... Could you post some screenshots of that working please? No way your card only hits 78c with 1.35v while running at 1780 on air. I can't believe that for a second.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2446501
lol what's going on in here?
OP: You will be fine till 1.4V when benching with the 780 Ti Classified under water. I would stick to 1.35V max for 24/7. Also note that the set voltage will actually be lower than applied voltage due to LLC and the board's power distribution. So you need to have a DMM to be sure of the volts applied.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2447015
I think you'll find that most places on the web state that 120c is the limit for your VRM temp. I think this all came to be with the 5970 VRM temp debacle when GPU editor Ryan Smith @ AnandTech had found out his 5970 was throttling while overclocking due the VRMs temps reaching in upwards of 120c. Most GK110 cards do not have a way to measure VRM temps via software. The Classified, Lighting, HOF and couple of Asus cards can to my knowledge. On cards like the Classified and Lightning, it's take quite a bit of GPU voltage for the VRM to get hot. Each GPU has 14 or 16 power phases to utilize and having that many really helps to dissipate heat from the mosfets/drivers.There may be a voltage hump you might need to hurdle, so increasing your voltage past 1.35v to 1.4v-1.45v for 35-75Mhz on the core is not worth the 1-2 FPS difference in games. For quick benching, I have been up to 1.5v monitored by software, which is never accurate.  I don't even want to know what a multi-meter might say.... 1.55-1.6v probably.
https://linustechtips.com/topic/182059-vrm-temps/#findComment-2447649
