Hi!
I'm in need of a wireless network solution for my pc. I don't know much about this subject and ask for help. What should I buy? I think i would prefer a PCI-e solution because it would look cleaner, but if I would benefit more from USB, then i'll go for that.
I am looking for a cheap alternative with reasonable performance. I live in sweden, but don't worry about checking availability of your suggestions.
Thanks beforehand!
Chassi: FD R4 window CPU: 3570k @4.5GHz GPU: ASUS 970 Strix @ 1450/7000 MHz PSU: FD Integra 500w
Mobo: Asus Sabertooth Z77 RAM: 2x4 Corsair Vengence 1600MHz SSDs: 2x Kingston 120GB RAID 0 (OS), Samsung 840 120GB (Steam) CPU fan: Noctua U12P Case fans: 3x140mm FD R2
https://linustechtips.com/topic/18175-need-a-wireless-network-card/
I personally use a TP-Link WDN4800, it's a great wireless card IMHO, works well and has a strong signal (after upgrading antennas). It supports 2.4GHz and 5GHz network. And it's pretty well priced. It also works naively (driverless) with Windows 8.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
thanks! I'll try it out, what antennas have you upgraded to?
