Switching ISP's. Need some help picking hardware.
Solved by Atlantisman,
Yeah I'm wondering if having them separately is better though. Also hoping I can get some suggestions from people who know about what's out there.
It is generally better to have them separate, for a number of reasons including:
Most modem/router combos i have seen are not that great.
Splitting the devices makes them easier to replace in the event of a failure.
and more.
That being said pretty much any of the Motorola Surfboard line of modems are good.
Then just pick a Asus router in your budget and you'll be set.
