Sound Blaster Cinema 2 - settings crash
I am not sure, whether does it work with speakers, I wanted to say that "Software doesn't crash when i set it on analog output instead of digital.
Thanks for claryfying things for me
And does it crash, when you set the SBC2 to Optical-Digital ?
So, solution for me would be that Dolby Digital Live (DDL) Sound card, right ?
What's the purpose / how does this card work ? It takes games surround sound (5.1 or 7.1), encode it to Dolby Digital and send to optical output ?
Does these cards usually comes with some software, that could emulate surround from my "stereo only" games / movies - that is Dolby Pro Logic, right ?
As this card need to process the sound, is there any notable lag ?
Edit: I checked Xonar DX - it's missing optical output ;(
No problem. I did try changing the setting, and it didn't crash on me. You need a sound card that has Dolby Digital Live. A lot of higher end X-Fi sound cards and the new Recon3D sound cards from Creative have that feature. For Asus, give the Xonar Essence STX a look. All this sound card talk makes me want to buy a dedicated card lol.
