O2 & ODAC combo is also in that price range? The Schiit combo isn't really a sound card though nor is the O2 & ODAC combo.
I'd say, if you need all the cool stuff you get with the STX, such as Dolby Headphone go for it. Otherwise I would go for something like the O2 & ODAC or the Schiit combo you mentioned. Especially with the Schiit combo, you could upgrade the equipment gradually, i.e. swapping the DAC for something better, then after a while saving some money swap the Amp for something better.
You could probably do with something even cheaper. What will the main use be?
https://linustechtips.com/topic/181386-sound-card/#findComment-2435965
I would have to go with the Xonar STX.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/181386-sound-card/#findComment-2435990
The fuck would you spend extra on a Loki for? The only reason it exists is for DSD playback, but if you needed that you wouldn't be considering an Asus card that can't do that.
Go ham, *grabs animal crackers*, this post looks like it should be fun.
https://linustechtips.com/topic/181386-sound-card/#findComment-2436309
