Hello everyone!
Specs:
GPU: nGeforce 560 TI
MB: MSI z77ag45
CPU: 3770k-i7
Windows 7
CM storm trooper Case
PSU: corsair 750 W
I have been overclocking my GPU and using heaven benchmark. While I managed to get a stable
1087volt (powerlimits not edited, not sure if I should)
950 core mhz
2150 mhz (edited after I got stability at 950)
and temperatures only getting up to 63-64 at fan speed on 75% (Considering a less noisy replacement)
Why is it that my tests on 1.15v, since my temperatures are this low, is basically unstable at even just 975 mhz core and stock memory frequency? I see artifacts, a few spikes and stuff right before a crash in heaven benchmark, usually 40-60 second into the test.
Also, is there any way I can break the fan barrier speed at 75%?
Should I touch other parameters to fix this problem, such as the power limits?
Are there problems in general using 1.15v with this card though I can manage to keep my temperatures low?
Thanks!
https://linustechtips.com/topic/181082-gpu-overclocking-problems/
What tool are you using to overclock ?
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
