so I'm building a rig for someone and it is based around the 6790k, and when I started it I saw pretty high idle temps about 50c, and I thought to myself that is unacceptable and opened it up and replaced the thermal paste with my arctic silver 5, and when I started it up I saw this
 post-50760-0-96964300-1405278679_thumb.p
now I never used a APU, but I don't think it should be this high
MoBo: 970A-D3P CPU: FX-8350 GPU: HD 7950 PSU: 1000watt RAM:8Gb of G,skill 1600
https://linustechtips.com/topic/180777-6790k-high-idle-temps/
AMD has stupid thermal sensors, sometimes they show negatives even, so dont look too much into it, if its not overheating
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/180777-6790k-high-idle-temps/#findComment-2427696
hhhhhmmmmm this CPU reminds me of a 4790k....
https://linustechtips.com/topic/180777-6790k-high-idle-temps/#findComment-2427725
I've got a Noctua NHC-12 se14. Kind of an low profile cooler.
But my case is crap and all my fans run at really low rpms so that might explain it.
this APU system is in a N200, and have to say if I was to build another mATX system I would use this case again
https://linustechtips.com/topic/180777-6790k-high-idle-temps/#findComment-2427769
That's actually good to hear. I've been eying the case.
But knowing me the upgrade will come when this case is obsolete.
Stock coolers - The sound of bare minimum
https://linustechtips.com/topic/180777-6790k-high-idle-temps/#findComment-2427796
just so you know you will most likely not be able to get the 24pin behind the motherboard tray, and if you are interested I have pics of the build
https://linustechtips.com/topic/180777-6790k-high-idle-temps/#findComment-2436663
