I'm planning on ordering the parts for my new, budget pc build (500$ budget) in about a week or so and I was wondering if the pc will run nicely, without any compatability issues. The new PC will mostly be used for gaming and I think that this PC can handle the newest games at high graphics.
CPU: AMD Athlon X4 760K 3.8GHz Quad-Core Processor  ($84.73 @ OutletPC)
Motherboard: MSI A88XM-E35 Micro ATX FM2+ Motherboard  ($67.99 @ Amazon)
Memory: Corsair Vengeance 8GB (1 x 8GB) DDR3-1600 Memory  ($79.99 @ TigerDirect)
Video Card: MSI Radeon R9 270 2GB TWIN FROZR Video Card  ($169.99 @ Micro Center)
Case: Zalman Z3 Plus White ATX Mid Tower Case  ($61.50 @ Mwave)
Power Supply: Corsair Builder 430W 80+ Bronze Certified ATX Power Supply  ($34.99 @ Micro Center)
Total: $499.19
Tell what you guys think about the PC, is it solid or would it be better to change some parts?
https://linustechtips.com/topic/180115-help-with-new-pc-build/
Total: $499.19
Do you have a hard drive already? I don't see any storage options.
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2419335
Motherboard: Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard  ($98.99 @ Newegg)
Video Card: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE Video Card  ($124.99 @ Newegg)
Case: Corsair 300R ATX Mid Tower Case  ($59.99 @ NCIX US)
Total: $483.93
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2419346
Get these instead that way you can upgrade to Broadwell later on.
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor  ($69.99 @ Amazon)
Motherboard: MSI Z97 PC MATE ATX LGA1150 Motherboard  ($79.99 @ Newegg)
Total: $149.98
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2419356
Total: $483.93
The reason why I went with the parts that I picked is mostly since there are in my local tech shop, since ordering from amazon.co.uk (I live in Europe) will increase the price by 200$. The parts that are show here are, in my opinion decent, its just I'm not really saving up that much money and I'm losing a good amount of performance (just my opinion, don't know if true). Mostly I'm going to keep the current list that I have, but what I would want to know if the cpu change will affect performance that much?
P.S. I am going to overclock the system.
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2419406
Total: $149.98
What kind of CPU would it better to upgrade to later on If I buy this CPU?
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2419411
The G3258 is practically a 2 core i7, when it comes to gaming. Especially when overclocked.
Going with this CPU lets you upgrade to any Haswell chip, or the upcoming Broadwell.
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2421953
Total: $149.98
I check the pricing in the local store and by switching the cpu and the motherboard the price for the system actually goes up and since I cant order the parts from amazon or something like that, I think I'll keep my current list as the PC I'm going to build.
Total: $499.19
All I want to know now is this going to work for gaming, is it a solid system and will there be no compatibility issues, is 430W PSU enough ( I am going to overclock the system)? Thanks for the help!
https://linustechtips.com/topic/180115-help-with-new-pc-build/#findComment-2425469
