Hey! I have a quick question for you. I have the Corsair Obsidian 650D and it has a 200mm front intake fan. The thing is that it is sooo loud! I just can't stand it anymore! I was wondering what would you recommend? The ones that come back the most are the Cooler Master Megaflows and some Bitfenix ones, but I wanted to have your opinion. I mainly want silent operation because all the computers are in the same room and when I play games, it's annoying for my parents to hear the fans.
Thanks in advance
-Keven
https://linustechtips.com/topic/180-good-and-silent-200mm-fan-intake/
@Dave
No unfortunately it does not accomodate 2 X 120MM natively. You have to do some sort of mod to the case which I don't really want to get into. Thanks anyways.
@Makol
Thanks for your opinion. I'll be sure to look at those if they are not too expensive.
Bitfenix Spectre and Spectre Pro are great. I have the Pro one on the side of my Carbide 500R
  • MB MSI Z77A-GD65
CPU Intel Core i7-2600K + Corsair H60 + 2x Alpenfohn Wing Boost
RAM Corsair Dominator 16 GB
GPU MSI Radeon HD6950 Twin Frozr II / OC
SC Asus Xonar D2X
SSD Corsair Force GT 120 GB
HDD WD Black 1 TB + Blue 1 TB + Green 500 GB
PSU Corsair HX650
Case NZXT Phantom 820 Black
Rheobus NZXT Sentry LXE
Monitor: 3x LG IPS231P + Philips 298P4Q
Hi-Fi Onkyo HT-S3305
OS Windows 8.1 Pro
@Dave No unfortunately it does not accomodate 2 X 120MM natively. You have to do some sort of mod to the case which I don't really want to get into. Thanks anyways. @Makol Thanks for your opinion. I'll be sure to look at those if they are not too expensive.
Ah ok, my apologies. As suggested earlier, the Bitfenix fans are a great buy, i haven't heard bad things about them.
Good luck :)
Ah ok' date=' my apologies. As suggested earlier, the Bitfenix fans are a great buy, i haven't heard bad things about them. Good luck :)[/quote']
No worries :) No one can know everything! Thanks for your opinion! Greatly appreciated.
Thanks. Now the question is : Is the pro worth the 7-8 bucks difference? lol
I got the Pro because it look better in my opinion and because a friend of mine sold it to me. The Bitfenix site is not working correctly so I cannot find any performance differences, if there are any.
  • MB MSI Z77A-GD65
SC Asus Xonar D2X
PSU Corsair HX650
OS Windows 8.1 Pro
I currently have a Cooler Master Megaflow. Does anyone think it's worth it to switch to the Bitfenix Spectre? Or are they pretty much on par with each other?
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
As mentioned above, as I read online, both seem to be the best performers. If it works good for you, i don't see why you should change it.
I have two Megaflows in my HAF X with two Spectres, the Megaflows are much more audible than the Spectres and seem too push about the same amount of air.
OSX/WiiU/XO/PS4/PS3/N3DS
There is a difference actually in the RPM, airflow, and size (the pro is 25mm while the non-pro is only 20mm thick, which doesn't matter anyway since it fits in a 650D).
Pro: http://www.frozencpu.com/products/14...20025R-RP.html
Non-pro: http://www.frozencpu.com/products/12...20020R-RP.html
Since you wanted something quiet, maybe go with the Spectre (non-pro)? Since it spins at a low rpm and doesn't produce much sound.
For my information' date=' are they regular Spectres or Spectres Pro?[/quote']
They are both normal Spectre fans.
Thanks ;) I wish we had a thanks button to thank people instead of a like one. Maybe both? I'll have to talk to Slick about this ^^. Anyways thanks!
I have the 2x 200mm spectre pro on my haf x for top exhaust.
They are pretty loud on full rpm but perform really well.
Also if u turn them down to half rpm they are actually very quiet but obviously dont perform as well.
Would def recommend tho. Not much choice for led fans like this in my experience.
would also go for a non-pro since they're not that expensive and still one of the best 200mm fans.. they still push a decent amount of air, and still stay quiet.. and i mean realy quiet
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
The Coolermaster megaflow (30mm thick) CANNOT fit in the front of 650d unless you remove the two hardrive cages.
The bitfenix spectre PRO (25mm thick) can BARELY fit into the front without removing the cages.
The bitfenix spectre non-pro (20mm thick) is probably the best choice, just use a 7v adaptor described by linus and it will be breezy and silent.
Thanks guys. I've made my choice and I'll probably go for the the Bitfenix Spectre (non-pro).
Again thanks a lot for all your help.
Spectre Pro moves a LOT more air just FYI. 148 Vs 48 CFM. You can always downvolt a Pro, you cannot speed up a non-Pro
