Anti fiber cloth and isopropyl alcohol. Don't waste money on thermal paste remover crap
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
I had some but I found that Akasa TIM Clean is better value, (30ml Artic vs 150ml Akasa)- same price.
Just drop it on the CPU, let it sit for 30 seconds and then use toilet paper. Will probably take a few attempts to get it perfect.
Q-Tips/Coffee filters and alcohol is supposedly one of the best ways.
Rubbing alcohol and a lint free cloth, such as toilet paper or a coffee filter. Q-tip for finishing touches and dry rub with a microfiber cloth to seal the deal.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
I just use paper towel and it works perfectly. And it must have worked since now that I've replaced the thermal paste on my grandma's computer it's running cooler (same cheap stuff too).
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
it is easier for me to buy this thermal paste remover then buy some alcohol
Will it do the job because it isnt that expensive
Alcohol is like $2. There's no need to buy something specialized when it does the exact same thing as something else.
As a question of curiosity, how is it easier? Rubbing alcohol is in every supermarket and pharmacy, whereas thermal paste cleaner can be only really found online or in  computer stores.
and what do i do with the CPU cooler do i need to clean it also with some thermal paste remover?
Exact same thing you would do with the processor.
Hello,
I want to remove thermal paste from my CPU.
I found this thermal paste remover  Arctic Silver ACN is it any good, and how do i remove it like on what do i put the thermal paste remover on?
Thank you in advance,
It is very good. you can used cotton pads, coffee filters and the microfiber cloths you clean eye glasses with are some of the ones i use.
A water-cooled mid-tier gaming PC.
