I've literally had this problem for months, can't even listen to music and can't play any games without audio, I've even formatted my HDD and re-installed Windows. When my computer is idle the crackling some what lessons, as soon as I open a program, type on the keyboard or move my mouse the crackling gets worse. I've tried disabling numerous devices in device manager such as realtek audio but the crackling is still there. I tried disabling the Ethernet to see if it was interfering but that didn't help. I've re-installed realtek audio manager like 5 times, even bought new speakers but I had the same problem. Anyways, I installed LatencyMon and ran a test and the message I got was "Your system appears to be having trouble handling real time audio and other tasks. you are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup.
CPU - i7-10700K, MB -MSI Z490 Gaming PlusRAM-Corsair Vengeance Pro 3200MHz, GPU - MSI GeForce RTX 3070 GAMING X TRIO, PSU - EVGA 650w Supernova G2 80+ GoldStorage - Samsung 970 EVO 500 GB ,WD 3x Samsung 860 EVO 500GB, Cooler- Noctua NH-D15S, CASE Fractal Meshify 2 Compact
https://linustechtips.com/topic/179718-unbearable-audio-crackling/
fx 8350, gigabyte ga-78lmt, crucial ballistix sport ram 8gb 1333mhz, r9 280x dual x, cm vs 650w gold psu, 1TB WD caviar blue
no i dont have another mobo, if i bought a super cheap usb audio adapter would that work? i just want some audio :'(
Yes. Personally would recommend the Syba DAC.
