it's good.
https://linustechtips.com/topic/179607-cryorig-cooler/#findComment-2412897
The cryorig is a brilliant cooler, it'll easily cool a 4790K with a decent amount of headroom for overclocking, I'd recommend it dependent on price. If a dark rock pro 3 or nh-d14/15 is cheaper, then I'd go for one of them. http://www.vortez.net/articles_pages/cryorig_r1_ultimate_review,1.html
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/179607-cryorig-cooler/#findComment-2413130
Yeah it's very good, hangs out with the D15 and dark rock pro 3
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/179607-cryorig-cooler/#findComment-2413618
its a beast.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/179607-cryorig-cooler/#findComment-2413659
