Computer Not Starting
Solved by SunriseRedeemer,
Hi,
To start I would re-seat the GPU and make sure that any power cables that need to be connected to it are in fact connected, and I would also re-seat the RAM and make sure it is in securely. Also make sure that all of the PSU cables needed to power the computer are in place 4-pin for CPU etc..
Hope this helps as a starting point..
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
