CM Hyper 212 EVO questions
Go to solution Solved by GuideMe002,
i have 212evo and i overclock my 4670k at 4.2ghz w/ acceptable temp.
The CM Hyper 212 EVO is only 30 bucks, and since I have the money, I might as well buy it and replace my stock cooler with the 212EVO. I know it's only $30 but I hope that it will meet my requirements:
1.) Be able to overlock my i5 4670k to at least 4.3 GHz
2.) Stay at temperatures similar to the ones that I have know whilst overclocked
and 3.) Be able to stay quieter than my heatsink.
Maybe I expect too much out of the heatsink, but it's worth a shot, right?
Any further advice, opinions of the 212 evo, and suggestions for another heatsink is welcomed!
i5 4670k, GTX 970, 12GB 1600, 120GB SSD, 240GB SDD, 1TB HDD, CM Storm Quickfire TK, G502, VG248QE, ATH M40x, Fractal R4
i5 4278U, Intel Iris Graphics, 8GB 1600, 128GB SSD, 2560x1600 IPS display, Mid-2014 Model
All the parts are here, just need to get customized cords to connect the motherboard to the front panel.
https://linustechtips.com/topic/178863-cm-hyper-212-evo-questions/
1. depends on the chip
2. depends on how high you overclock your chip and your voltages
3. yes most likely that it will be quieter
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
We can't say what your overclock will be or what your temps will be. The overclock is so cpu dependant nobody can tell you anything about yours without guessing, you'll have to figure that out yourself. Same for temps, nobody knows your config, your fans, rooms temps, how the case is located, humidity, etc. There is so much to take into account that varies with each user nobody can tell you what you'll experience. Only you from testing can.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
The overclocking part is based on how well you chip did in the silicon lottery. Best case scenario, it can do 1&2, but it can most definitely do #3. If you need better cooling, you can get an AIO or another fan for your Hyper 212 Evo.
How would I do that? Where would I put the other fan?
It comes with another set of clips that you put on the back of the heatsink.
Great!
Are there any other heatsinks you guys suggest?
Great!
for that price just go with the 212 Evo.
Thanks guys!
Guess I got my answer
