Hello everyone
I am a first time builder and I am not so sure if i have everything i need and if everything is compatiple and fits.
Here are the parts i have selected till now:
Case: Fractal Design Define R4 Black
Mainbord: Gigabyte Z97X-SOC
CPU: i7-4790k
Ram: Kingston HyperX Fury Black DDR3-1866 2x8GB
GPU: zotac GF GTX 780TI AMP 3GB DDR5
Cooling: Crosair H100i; 2 Noctua NF-F12 PWM (for the H100i); 4 Noctua NF-a14 Flx
PSU: Crosair RM850 (a bit too much i know, but i migth consider adding SLI later for upgraiding)
Storage: 2 Kinston Technology HyperX 3k 120GB SSDs (for RAID0); WD green 2TB
Optical: I dont know what exactly what i have, just the one of my old PC
I hope you guys can help me...
https://linustechtips.com/topic/178549-my-first-build/
swap the Kingston SSD to Samsung Evos
Seasonic or CoolerMaster V850 PSU may be better
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/178549-my-first-build/#findComment-2397438
EVGA GTX780Ti SC ACX cooler will be nice
https://linustechtips.com/topic/178549-my-first-build/#findComment-2397453
Thanks for the fast answers
The budget is around 2200
The Zotac card was the ceapest option for a 780Ti. So should i get Gigabyte GTX 780 Ti OC instead? Its like 10 bucks more.
The ACX cooler costs 150$ more, so no real option.
And i but my trust in you guys with the SSDs, I`ll get the Samsung 840 EVOs
Is that about it?
https://linustechtips.com/topic/178549-my-first-build/#findComment-2397493
Is that about it?
yes the Gigabyte WindForce is at least a better brand over the Zotac
https://linustechtips.com/topic/178549-my-first-build/#findComment-2397508
