600T AIRFLOW CONFIGURATION HELP?!?!
It depends on what set-up you have, the stock configuration is fine in most scenarios.
When I had my GTX 590 in a 600T the front fan and the GPU exhaust were going against each other, as such, I got worse temps on one of the GPUs.
Have more intakes than exhaust and you'll be good.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
