Looking at doing some changes at my build, and they include some Noctua fans. If I wanted a 140mm fan designed for Static pressure for my H90, which would I buy? Also which 140mm Noctua's are best for case airflow?
Thanks for the help.
CPU: Intel I7-4790k | MOBO: Asus Sabertooth Z97 Mark 1 | Ram: Corsair Vengance 32GB 1600hz | GPU: EVGA GTX980 Reference
PSU: Corsair EVGA G2 850W  | SSD: Intel 730 Series 480GB, Kingston SSDNow V300 120GB | HDD: WD Black 1TB
 CPU Cooler: Corsair H105 | Case: Corsair 760T (White) | Peripherals: (2)Asus VS247H-P, Corsair M65, Corsair K70 RGB w/ Brown Switches
https://linustechtips.com/topic/178329-noctua-fans/
NF-A14 PWM for your radiator. I use A14s for my case's intake and exhaust as well, pretty much the best 140mm noctua unless you have space for the NF-A15
proud owner of alienware 13 with graphic amplifier and also a alienware X51 gaming PC!!! really powerfulL!!
xoxo samantha <3
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2394436
I'm assuming I should go for the NF-A14 PWM? I have also seen the FLX recommended but I'm not sure what the difference is other than its a 3 pin.
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2394535
I'd go all PWM, I don't really see any reasons not to. Your motherboard will have much more control over the fans and you can ramp/up down as required. They should also be backwards compatible to 3-pin anyways.
xoxo samantha <3
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2394545
Thanks man, planning on upgrading to the 760T soon and will see how case temps and noise are with my current fans. Once I test it I will determine if I will step up to the Noctuas as I don't care for their looks but everyone says they are some of the best performance wise.
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2394570
Changing case fans only affects noise, it won't make any noticeable difference in temps.
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2394856
http://linustechtips.com/main/topic/172101-noctua-fans-in-a-case-pressure-or-flow-silverstone-ps07/
Check post #4
https://linustechtips.com/topic/178329-noctua-fans/#findComment-2399039
