I can def. tell that a wired mouse works way better than the wireless mouse I have ( Logitech MX5500 combo) but I've been reading about the new Raser Wireless mouse and I'm hearing good things. Please take a moment and try a wired mouse vs a wireless mouse if you use one and let me know whats the best out there :)
https://linustechtips.com/topic/17689-gaming-wireless-mouse-or-not/
You could always get a wireless mouse that you can plug in via USB. Razer do a couple :)
thats also how you charge the razer ones :D dieing battery? plug it in via usb and keep playing while charging
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
I prefer wired because i have actual speakers.
the waves do not like eachother
just as much as i dislike batteries
AMD Phenom II x4 955 - Gigabyte GA-870A-UD3 - XFX HD7870 CORE - 60 GB OCZ Agility 3 - 1 TB Western Digital Green - 1 TB Hitachi DeskStar
OCZ ModXstream 600W - 16 GB Corsair XMS3 - Cooler Master HAF 912 Plus - Logitech G110 - Speedlink Kudos - Sennheiser HD 518
Steam The reason I am still alive Dark Theme
If you play FPS on any competitive level do not play with wireless mouses, but if you are not then ok i used for a long time a wireless Logitech mouse but when i witched to wired i could feel whenever im on a wireless mouse some kind of lag input.
AMD Radeon 7870 Gigabyte OC / Intel i5 3570k / ASrock Z77 Pro4 /Samsung 840 EVO 250GB / WD Blue 500GB 7200rpm / Kingston HyperX T1 2x4GB 1600mhz / SeaSonic 520w M12 / Thermaltake v4 Black
I really couldn't recommend Razer to anyone, wired or wireless unless we were talking about the Deathadder.
Akula  | Dimastech Test Bench | Watercooled | Tri GTX 680's | Build of the Week
Mercury | Caselabs Mercury S3 | Watercooled | GTX Titan | Build of the Week
Armada | Define R4 Titanium | Watercooled | EK Waterblocks | Newest Buildlog
I personally love the Razer Naga, some people don't like the 12 buttons but I use them all the time playing WoW, Farcry etc. plus it's wired and wireless. I use wired most of the time but I don't notice a huge difference in wireless either.
Me: Yeah I just really can't get my H220 working again, I've tried everything that was suggested in the forum.
Brian (Swiftech Support): Hmm, have you tried slapping it?
I prefer wired mouses, just because I don't want to deal with batteries / plugging in some cable to make i charge.
If you're thinking about performance, then there shouldn't be a reason to worry. Most gaming grade wiresless mouses will have the same latency as wired mouses.
The Logitech g700s would also be an option :)
I'm hearing a lot of good things about logitechs g700s
I use the normal G700 and even then I cant notice a difference between wired or wireless.. No lag at all..
So I'd definitly buy wireless again (If I know its a good one ofc not some random mouse)
Yarrrr, ye be warned lily-livered scallywags
https://www.youtube.com/watch?v=SLMJpHihykI#t=93
Even if you aren't competitive, I don't know why anyone would hinder themselves :P
To the OP, I have used a G700 for a few months then switched to the g400 after I broke the g700 cause angers. The g400 is just a better feeling mouse. BUT it's not because one's wireless and one's not. It has to do with the sensor more then anything else. I never noticed a difference between wired and wireless and I'm rather picky about that stuff. But honestly, just get a g400 and be happy
Wireless mice do have an minor input lag although it may be negligible (For twitch gaming this can be a huge factor though!), as well as having the need to swap batteries/recharge.
Personally i prefer wired mice to remove all the hassle with handling wireless mice.
+1 mate, all so true! Another thing to consider that I don't think most do is that batteries within the mouse do add some weight you know! So mice with batteries will be quite a bit heavier, (dunno if you like that or not) so keep that in mind.
Is this the real life? Or is this just fantasy?
I use a Razer Mamba and I don't notice any input lag while in wireless mode. I also love the convenience of a wireless mouse and not having to deal with a cord. The only issue is sometimes my macro profiles don't auto switch, or take a really long time, when I start a game. ie. I set the DPI up/down buttons to gadgets in BF3 and I don't check the mouse profile before I start playing, then I die cause I can't drop a med-pack. :( In wired mode, there are no problems at all. I hope this helps.
No matter how good a wireless mouse gets you have to ask yourself "do i want to recharge my mouse?", If that's a no, then get a wired mouse.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
If you're a casual gamer and don't like wires, wireless is fine...If you're pretty serious about it, forget it. Input lag + battery dying at a bad time = very angry gamer.
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein
