hi
today i open my case and clean it after i clean my case
i left  side panel open and then  start my pc then i see red light coming from memok button (1 or 2 second)
i control my rams  they  are look fine,-windows  still says 8gb
but it scare me little bit   :(
is it serious thing or not
sorry for my bad english
my motherboard asus p8h77- v le
https://linustechtips.com/topic/176534-memory-ok-red-light/
Run Memtest86 for a few passes just to double check.
You can find Memtest86 by googling
CPU: AMD Ryzen 7 3700X - CPU Cooler: Deepcool Castle 240EX - Motherboard: MSI B450 GAMING PRO CARBON AC
RAM: 2 x 8GB Corsair Vengeance Pro RBG 3200MHz - GPU: MSI RTX 3080 GAMING X TRIO
https://linustechtips.com/topic/176534-memory-ok-red-light/#findComment-2366783
