control panel registering my overclock
Go to solution Solved by harrynowl,
Intel CPUs say i5 2500K @ 3.3GHz always in Control panel
I have had a mosey through the forums but i cant find my answer so.......
CPU-INTEL i5 2500K 3.3GHz
MOTHERBOARD- ASUS P8Z77
I am just beginning to overclock my cpu and i have started with 3.3 to 3.6. I am pretty condifdent in that i know how to do this but my overlock is not registered in my control panel system settings but i can see it when using cpuz
Is this common or have i missed something along the way?
https://linustechtips.com/topic/176503-control-panel-registering-my-overclock/
This is usually how it is. Overclocks do not get registered in Control Panel. You can see them in CPU-Z though.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
when i change a OC it takes like 2 days for it to register. see what it says in the taskmanager/other programs
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
