I need help learning c++
Go to solution Solved by Nuluvius,
This: http://pluralsight.com/training/Authors/Details/kate-gregory
She gives a very good beginner friendly introduction that is at quite a soft pace.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/175992-i-need-help-learning-c/#findComment-2356000
You should have probably started with an easier to learn language.
https://linustechtips.com/topic/175992-i-need-help-learning-c/#findComment-2356051
