Hi guys
im new to the forum :D
I have a question for u... my Brother claims that if his GPU hits 50-60c while Running a game he will notice a performance drop, and that this is normal... what do you guys think of that?
My maximum observed temperature is around 60 degrees and I haven't noticed any performance throttling.
https://linustechtips.com/topic/17576-gpu-and-temps/#findComment-202701
try a burn-in test, they display temps and FPS, so if there is any performance drop as temps go up, the numbers should tell you.
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/17576-gpu-and-temps/#findComment-202865
If he REALLY is seeing a drop in performance then it can't be the GPU. Something else must be overheating to cause the drop in performance, perhaps his CPU. A GPU wont throttle itself until it reaches around 95-100c.
Simple Stryker (Now Finished  ;) )
The Terrible HP
https://linustechtips.com/topic/17576-gpu-and-temps/#findComment-202880
It's a Kepler GPU. They throttle at 70, 80, and 90 degrees to keep temperatures in check. Tell your brother to download MSI afterburner and increase the power limit to the maximum.
CPU: Intel i5-2320 @ 3.9gHz
GPU: MSI GTX 670 PE @ 1411/7387
I wanna go fast! :P
https://linustechtips.com/topic/17576-gpu-and-temps/#findComment-203015
