Hey,
I am thinking about upgrading my processor to an i5- 3570k and thus also need to upgrade my motherboard, I have been reading around and cannot decide which to get.
These are what I am thinking, my budget is around £150
Asus P8Z77-V Pro
http://www.amazon.co.uk/Asus-P8Z77-V-Motherboard-iControl-CrossFireX/dp/B007KZQE6C/ref=cm_cr_pr_product_top#productDetails
MSI Z77A - GD65
http://www.amazon.co.uk/dp/B007JRGW1I/?tag=pcp0f-21
MSI Z77 MPOWER
http://www.amazon.co.uk/MSI-Z77-MPOWER-LGA1155-INTEL-Motherboard/dp/B008VZROK0/ref=sr_1_1?s=computers&ie=UTF8&qid=1368866155&sr=1-1&keywords=MSI+Z77-MPOWER+LGA1155
MSI Z77A - G45
http://www.amazon.co.uk/MSI-Z77A-G45-Motherboard-Pentium-Celeron/dp/B007JRGVUA/ref=sr_1_2?s=computers&ie=UTF8&qid=1368816689&sr=1-2&keywords=MSI+Z77A-G45+motherboard
The cheaper the board is the fast I can save for some liquid cooling however when around the £150 mark it will be a month before I will be able to pick it up, I am looking for a nice motherboard to be able to last for a few years.
Thanks for your advice.
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/
Honestly all those boards are great - I have the Z77A-G45 now with a 3570K and love it, but I mean it all comes down in this case to specific features you like between the boards, be it connectors, audio, bios software, etc. What stuff do you really want/need in your board? If you want to save a bit of money for watercooling i'd personally go for the GD65.
But then again, have you considered waiting a couple weeks to see what Haswell has to offer?
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202175
How about a blue and black themed mATX build, perhaps in a 350D? This board would be suitable.
http://www.novatech.co.uk/products/components/motherboards/intel1155z77chipset/microatxformfactor/90-mibi10-g0eay0gz.html
I used one for my parent's build and can recommend it.
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202178
If you are planning on a mATX build, with 150 quid, you can easily get a maximus V gene. However, if you are planning on getting this, you might want to wait for a while because the gene VI will be released in early june.
But if you are planning on a standard atx, Sea aych is pretty much spot on.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202188
But ATX motherboards are a waste unless you plan on having a triple graphics card setup or the like. His budget isn't excessively large so he'd get a better bang for the buck going with mATX.
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202216
ATX motherboards aren't a complete waste in modern situations as they allow more future expandability. I however was assuming that kernow needed a atx motherboard due to the fact that his case may be a mid-tower and putting in an matx would look out of place.
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202244
First of all it doesn't always look out of place, there are many factors to take in to consideration; also, what would "future expandability" entail? If he wanted a good DAC, external solutions perform better than sound cards, and the only other card that he might want is another GPU, which this mATX board supports (the other one supports CrossFireX).
http://www.novatech.co.uk/products/components/motherboards/intel1155z77chipset/microatxformfactor/90-mibhy0-g0eay0gz.html
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202277
Thanks for your quick replies! Ok, Sorry I should have probably posted my situation,
Currently I have:
Case: Corsair Carbide 500R Mid Tower
CPU: Intel Core 2 Quad Q9550 @ 2.83GHz ---> upgrading
Cooler:                       Wish to Buy ------> Corsair H100i
PSU: Corsair TX650 V2
Motherboard: Asustek P5N73-AM ------------>   wish to upgrade
Ram: 4Gb DDR2 -------------------->                    To upgrade
GPU: ASUStek Geforce GTX 500 GDDR5 1gb
I have £350 in total to upgrade, I didnt realise about this Haswell coming out, Income is limited at the moment but i qualify as a nurse in September, I can save for the cooler and replace the stock fan with that in a motnh or so if needed. Looking to be able to play Rome Total War 2 etc to the best of the comps ability. I am a bit behind on the overclock stuff etc but am computer literate so I am positive I can learn/ ask you guys for advice.
What do you guys think?
https://linustechtips.com/topic/17535-motherboard-upgrade-advice/#findComment-202300
