what do you use it for? OC? noise tolerance? also what cpu :P?
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
The cooler is less likely to die in that humidity than the rest of your system. It'll be fine, and work better than many other coolers.
i wanted an nh-d15 but it's not stocked anywhere in the UK yet *cries* i have to settle with a H110
"settle" is such a sad word to use here when you're talking about two really good coolers :P
well i did have a H100i, the pump broke, got a replacement... pump broke AGAIN... now im waiting for my replacement h110 and since i dont trust AIO's anymore i really would have preferred the NH-D15... ugh
I'm using a i5 4670k I don't care about the noise I just care that my component are really cool
Tropical nation dude sometimes got an 90% humidty average
Don't worry, that cooler will be more than fine. Just don't go crazy with overclocking and if you can munt some fan filters on the case fans, they could help filter the humidity.
sudo chmod -R 000 /*
Humidity gives the air a higher specific heat, which is actually better for cooling at that high ambient temperature. Humidity only becomes a problem when there's compensation, which only happens when the pc is colder than ambient temperature, so don't use peltiers etc. (no Cooler Master V10 for you). The NH-D15 is a fine cooler and will serve you well for almost any CPU. Just make sure you don't have any clearance issues as that cooler will often make your first expansion slot unuseable which may cause problems if you want SLI. Also make sure your case is well ventilated as the temperature the cooler tries to cool down to is the inside case temperature rather than ambient.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
http://www.amazon.co.uk/gp/aw/d/B00JJY25NI/ref=mp_s_a_1_1?qid=1404389295&sr=8-1π=SX200_QL40
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
picked up my H110 about an hour ago, i was dealing through a local store who's supplier couldnt find anyone with any of them in stock, i'll just have to see how this one goes, but im not overly enthusiastic
damn that is unlucky, if you only ordered it an hour ago i'm sure you could cancel it
i've been dealing with the guy for nearly 6 months, he works in his own store, i doubt he'd order from amazon, he has his own supplier, i order things at trade prices and pick it up next day so if his supplier doesnt have it im pretty much boned
Instead of buying pc cooling, consider air conditioning lol.
Seriously how do you even play games in 30C and such high humidity. xD
{PC} i5 4690 | Gigabyte R9 290 | Asus H97-Plus | 8GB Kingston HyperX Fury | CM Hyper 212 Evo | Samsung 840 Evo 120GB | Adata SX900 256GB | Seagate Barracuda 2TB TT 650W Smart Fractal Design Define R4 Windowed
{Audio} Ear/Headphones: HiFiMAN HE-400, Westone 4R, Shure SE535 Amp: Little Dot MKIII, Fiio E11 Dac: LIttle Dot Dac II
Just wanted to jump in this, I have the nhd15 with the new devils canyon, Air cooled and ASUS 5-way optimization got it up to 4.7 @ 1.35 volt and I never see it past 39 degrees. I usually have my comp on for 18 hours straight a day running games and audio production applications, I also live in TX where its been 98 degrees and 100% humidity. All in the NZXT H440. I'm going to run some benchmarks.
