i want to build my new first desktop but currently i have only this
MSI Technologies GeForce GT 630 4GB DDR3 PCI Express 2.0 Graphics Card
MSI Intel H61 DDR3 1333 Intel LGA 1155 Motherboard
Kingston KTH9600B/4G 4GB DIMM 240-pin DDR3 PC3-10600 RAM
are this compatible each other?
can you suggest what power supply,processor,hdd should i use?
https://linustechtips.com/topic/17429-need-help/
They should be all compatible. So are those the parts you chose or parts you already own?
Also, what's your budget and what are you using the computer for?
Where are you located? This determines where to shop.
https://linustechtips.com/topic/17429-need-help/#findComment-200840
Moved to NB&P
https://linustechtips.com/topic/17429-need-help/#findComment-200903
@woodenmarker i already own those sir , im from philippines parts here are expensive so i shop at online amazon or walmart
@911^Nemesis for gaming don't have much peny
i can spend more 500$ to get processor,Power supply,hdd and case
hi there kababayan! have you tried looking at dynaquestpc or gilmore? parts are cheaper there (well still higher than US prices but close enough)
| i5 3570 | Palit GTX 680 jetsream | Gigabyte Z77x-ud3h | Corsair Vengeance 2x4 1600mhz | WD Caviar Black  1TB | Corsair TX 650m | Coolemaster Hyper212 X | NZXT Pantom 410 | Asus VS239 | Logitech G400s |
Click here to learn how to troll
https://linustechtips.com/topic/17429-need-help/#findComment-200907
In that case, here is what the rest of the build I would make :)
http://pcpartpicker.com/p/Y6lP
I didn't add in the things you already had to look at the price of everything together :)
Edited by SirReallySam
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/17429-need-help/#findComment-202309
thank you for that sir,
what can you say on my VGA? for gaming
and can you please make new items that worth 300$ because i already spent 200$ for my hospital bill today :(
https://linustechtips.com/topic/17429-need-help/#findComment-202646
What's wrong? Or is it personal?
PROFILEYEAH
https://linustechtips.com/topic/17429-need-help/#findComment-202684
This may or may not break your budget a bit:
http://gyazo.com/a3642e5454ec19967e4e658824c701ea
https://linustechtips.com/topic/17429-need-help/#findComment-203068
