Motherboard Help
Go to solution Solved by ForsakenLive,
The H97 Asrock Fatality is a really good pick!
PCPartPicker part list: http://pcpartpicker.com/p/NxZVGX
Price breakdown by merchant: http://pcpartpicker.com/p/NxZVGX/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($187.98 @ SuperBiiz)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard  ($84.99 @ Newegg)
Memory: Kingston Fury Red Series 8GB (2 x 4GB) DDR3-1866 Memory  ($72.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($52.92 @ Amazon)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card  ($279.99 @ Newegg)
Power Supply: Fractal Design Integra R2 750W 80+ Bronze Certified ATX Power Supply  ($64.99 @ NCIX US)
Total: $743.86
I am currently building my first PC mainly for gaming. I would really appreciate if anyone could help me find a motherboard. I am trying to find a good ATX motherboard for this build http://pcpartpicker.com/p/CWnPgs keeping the total price under $750. This is the case http://pcpartpicker.com/part/enermax-case-eca3290ag i didn't put it in because i already have it. I need it to be socket LGA1150.
https://linustechtips.com/topic/174110-motherboard-help/
no need to change the mobo, you will be good with Gigabyte
unless you want to upgrade to the K series CPU then you will need a Z87 or Z97 board
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/174110-motherboard-help/#findComment-2312476
Total: $743.86
https://linustechtips.com/topic/174110-motherboard-help/#findComment-2312495
Total: $743.86
Thanks for the help man really appreciate it.
https://linustechtips.com/topic/174110-motherboard-help/#findComment-2312674
