MEGA =10^6
KILO = 10^3
You need to change bits to bytes( 1 byte = 8bits)
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305767
its the middle of freakin summer, stop doing homework
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305772
I need to calculate file transfer times but how would I do that?
Here's problem 1: File size = 100MB transfer rate = 56Kbps  Transfer time = ?
How would I solve this?
Any help is appreciated!
100MB = 819200 Kb
    819200 / 56
 14628.57 seconds
     ~4 hours
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305789
I need to show my work :P but thanks
Was what I gave you enough?
Edit: Is that a yes?
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305804
are you doing majors? what year are you in, in college
[spoiler=My Beast Rig Damocles]Case: Coolermaster Storm Stryker Motherboard: Asus x79 deluxe CPU: Intel I7 4960x @3.6GHz (soon to be oc) RAM: Kingston HyperX 64GB @2400MHz GPU: Nvidia Geforce GTX 770 (Gigabyte) @4GB PSU: Corsair RM1000 Fully modular CPUCooler: Corsair H100i Watercooling Storage: Seagate 2TB SV35.6 SATA 6GB/s 7200RPM 64MB 3.5"   x2  Sound: Creative Soundblaster ZxR sound card
This is my old pc which I am reamending to be a media server or a nas. Motherboard: Generic fujitsu CPU: Intel pentium G640 @2.8 GHz RAM: 4GB generic fujitsu memory PSU:  CPUCooler: Stock intel cpu cooler Storage:  Fujitsu MHZ2120BH @120GB, Soon to have a HDD for more storage.
_ASSASSIN_ Jerakl
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305883
It's helping thanks :D
Would there also be a site to where I can figure out where you got 100MB = 819200 Kb and also why did you divide by 56?
Just google it.
100Mb to Kb, google has a little box at the top with the answer.
Well since they're both the same unit, Kilobits, I can now divide the amount of Kilobits by the transfer speed to find out the time it would take to transfer the file, assuming that you have an unwavering transfer speed of 56Kb/s.
Because that gives you a large amount, 14628.57 (seconds), you would typically convert it to the next unit of time (minutes).
To do so you would divide 14628.57 by 60 since there's 60 seconds in a minute, and you'd get 243.81 (minutes), which still isn't a particularly appealing number, so we'll convert it to hours.
As there's 60 minutes in an hour as well we'll just divide 243.81 by 60, and we get 4.06 (hours).
But how long is .06 of an hour?
Multiply it by 60 to revert it to minutes and you get 3.6; So that's roughly 4 hours and 4 minutes.
You could also just say, " Well I know that 60x4 is 240 so it's just over 4 hours."
Hope that explains it, might've made a small mistake in there, if so someone please correct me.
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305885
Doing summer classes as a Freshman :P
Just google it.
Thank YOU! Makes more sense now!
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305897
Just wondering, do you have a book of answers?
Want to make sure I'm not misleading you.
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305905
I do have a book but I've had no luck finding formulas or anything explaining this :\
No, I just wanted to know if I got the right answer.  :D
Assuming I got this right feel free to pm me for help.
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2305917
what college class is this from. It sounds like a high school freshman problem. Just use simple dimensional analysis
This is a very basic example of dimensional analysis. Use it whenever dealing with changing units to other units
https://linustechtips.com/topic/173612-help-with-some-hw/#findComment-2306370
