Cooler Master GM550W
Go to solution Solved by Askew,
easily
Will this power supply be able to run an i5 4590 and GTX 770 in an ITX PC. I added the ITX part as I know they consume less power overall.
It has 42AMPS on the 12v rail and I think that is the recommended amount for the 770. I'm shopping at scan.co.uk if there are any other PSU's you would go with.
http://www.scan.co.uk/products/550w-cooler-master-gm-series-hybrid-modular-80plus-bronze-1x120mm-atx-v231-psu
https://linustechtips.com/topic/173048-cooler-master-gm550w/
