CPU Cooler for z97 lga 1150
King_Gamma
Hey guys I am having some trouble finding an cooler that is compatible with the z97 lga 1150 motherboard. I will be overclocking my i7 4790k with it and I want it to be quiet. My price range is up to $100 USD.
Thanks!!
Thanks!!
Uhm.
What will you be using it for?
There's tons of coolers, but you may not NEED a $100 one.
Also, what case do you have? And, what does the rest of your system look like?
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
Noctua NH-D14/D15
Be quiet Dark Pro 3
Noctua NH-U14S
Cryorig R1 Ultimate
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
Hyper 212 evo or a corsair h1xxx, either are good but different needs
My Rig
PCPartPicker part list: http://ca.pcpartpicker.com/p/kGNksY
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor  ($379.00 @ shopRBC)
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($34.99 @ NCIX)
Motherboard: MSI CSM-H87M-G43 Micro ATX LGA1150 Motherboard  ($78.83 @ DirectCanada)
Memory: Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory  ($139.99 @ Memory Express)
Storage: Kingston Fury 120GB 2.5" Solid State Drive  ($71.34 @ DirectCanada)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($92.95 @ Vuugo)
Video Card: Gigabyte Radeon R9 280X 3GB Video Card  ($298.98 @ Newegg Canada)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($125.98 @ Newegg Canada)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($66.99 @ NCIX)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)  ($116.00 @ shopRBC)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120mm  Fans  ($23.99 @ NCIX)
Monitor: HP 22xi 60Hz 21.5" Monitor  ($187.11 @ Amazon Canada)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($114.99 @ NCIX)
Mouse: Razer DeathAdder 2013 Wired Optical Mouse  ($76.99 @ Amazon Canada)
Headphones: Kingston HyperX Cloud Pro Headset  ($78.98 @ DirectCanada)
Total: $2074.22
Prices include shipping, taxes, and discounts when availableGenerated by PCPartPicker 2015-04-10 15:33 EDT-0400Build log http://linustechtips.com/main/topic/303263-the-dell-from-hell/#entry4121100
Phone Compassion Spreadsheet https://docs.google.com/spreadsheets/d/1EN6s426gyxqPloIqT4wQ7Y7yovkkQy_5B3djVN-N-R8/edit#gid=0
Gta V Pc Online Crew http://linustechtips.com/main/topic/344773-unofficial-linus-tech-tips-gta-v-crew-pc/
Uhm.
3D modeling and gaming
Dark Rock Pro 3
Are you sure that will fit. I have a MSI Gaming 5 motherboard.
It'll fit. Now, whether or not it'll fit your case or if your RAM has enough clearance is another story.
| CPU: An abacus | Motherboard: Tin foil | RAM: 2 Popsicle sticks | GPU: Virtual Boy | Case: Cardboard box | Storage: Cardboard | PSU: 3... Er... Make that 2 hamsters | Display(s): Broken glass | Cooling: Brawndo | Keyboard: More cardboard | Mouse: Jerry | Sound: 2 Cans of SpaghettiO's |
Thanks!!
You have to provide the case model and memory to get an accurate answer.
NZXT H440 and ADATA xpg 1.0 16gb (they are low profile).
Noctua NH-D15 - still waiting for good benchmarks, but early reports suggest this will easily replace the NH-D14 and does better than the NH-U14S
Noctua NH-U12S - quiet, a little smaller than the D15, only a couple of degrees worse cooling.
Cooler Master Hyper 212 EVO - low cost, decent performance.
I hate the look of noctua and I have a windowed case
If you had more budget I'd suggest the Kraken X61 run in silent mode but the X41 in silent mode will do a decent job.
what about the dark rock pro 3.. would that fit?
Phanteks makes similar CPU coolers. They also come in a variety of colors like the Sexy Santa one below. This is a 140mm CPU cooler.
All four color options. There might be more. These are the 120mm cooler ones, though.
Noctua NH-D14/D15
Be quiet Dark Pro 3
Noctua NH-U14S
Cryorig R1 Ultimate
This.
Just pick any of them that fits (D15 has the best performance)
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
I believe it does. But it will overhang memory and the heatsinks.
I think you should go with a dual tower cooler for best temps and noise.
