Hy guys,
I want to build my first water loop, I own an NZXT Phantom 530, so i chose this kit...
http://shop.xs-pc.com/xsp/XSPC-RayStorm-D5-Photon-AX360-WaterCooling-Kit_43122.html
I wanted to add another radiator, the ex240, and add the gpu block...
How should i connect these things?
The ax360 is 40mm thick, right? Because i measured the space from the mobo to the case and the nearest thing would be the cpu power cable...
Thanks,
EMENCII
rig: i7 4770k @4.1Ghz (delidded), Corsair Vengeance 8GB 1600Mhz, ROG Maximus VI Hero, Noctua NH-D14, EVGA GTX980SC, Samsung 850 EVO 500GB, Corsair SF600, self-built wooden Case, CoolerMaster QuickFire TK, Logitech G502, Blue Yeti, BenQ GW2760HS
https://linustechtips.com/topic/171360-first-water-loop/
You need to add another 25mm to the rad thickness (fan). The mounts on your case should be slightly offset towards the front side panel though, you shouldn't run into problems with the rad hitting the CPU power cable. Otherwise I recommend compression fittings and 16/10mm tubing for connecting everything.
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2277137
I thought to mount the fans over the case, like fan->case->rad...
I've seen that that kit has an orizontal mounted res, so where should the water flow go? Which direction?
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2277152
The in and out ports are at the bottom the reservoir. Your manual will tell you which is in and which is out.
Primochill 1/2 ID 3/4 OD is the best.
Bert & Ernie before squirting spermie.
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2278163
the pump/res combo in that kit is meant to be mounted vertically, otherwise you'll have trouble filling it. Other than that, loop order doesn't matter. Do whatever gets you the cleanest runs.
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2278519
ive the same case, you may wanna look into my build and figure out how to route things,
the rad i have is 46mm thick, it fits very tight in the top, but its fine it doesnt interfere with anything, but when i swap it with my 360 rad it will be less thick
ill be adding 360 rad in 2 weeks, this will be my loop
post-68200-0-75893600-1403726753_thumb.j
but  am goin to get acrylic tubing later on, so if i wasnt goin to get acrylic tubing, id probably do the same as this build
honestly the res wont fit in this place so thats why i have it at the left side lol
i am planning to mount HDD with this bracket in 5.25 bay tho
http://www.frozencpu.com/products/19391/hdc-108/Akasa_525_to_35_Device_HDD_Adapter_AK-HDA-08BK.html?id=z5HMddpt&mv_pc=18296#blank
and my SSD is mounted in the back
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2280206
Not a big fan of acrylic. Thats jayztwocents' build, just do that, best option.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2281624
Thanks guys, this is exactly what i was looking for... ^^
I like the gpu->rad->cpu config, i think i will go for that...
How about to buy a crossflow rad, for the front one? So one port is in the upper side and one on the lower?
https://linustechtips.com/topic/171360-first-water-loop/#findComment-2282718
