isnt shadowplay still in beta?
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275785
Nevrmind is
Upload:1 mbps
Download:15 mbps
Streaming with that connection is going to be a poor experience, it isn't fast enough to do decent quality, when you stream it's all about the upload speed and not the download because you are sending stuff out not downloading it to you.
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275846
Youtube Yes, LiveStream I don't know.
Shadowplay uses VBR and compresses to H.264, if you sent it to YT it will get re-encoded to H.264/AVC.mp4 and compressed, it ends up looking like ass I've done a lot of experimentation with it. (there's a thread I made in the guides/tuts section covering this)
The better method for youtube specifically is to capture using a lossless codec, edit it and then finally render the final cut to H.264/AVC in the mp4 container which is what youtube natively uses, this way you will only undergo compression and not a re-encode.
Have a look at this
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275860
What should upload be ? Atleast 5
TheEducatedGamer
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275874
Have a look at this
Ok
TheEducatedGamer
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275877
It is great for both Youtube and Streaming. Anyone claiming it's no good for Youtube is simply setting their recording options too low to begin with. Youtube compresses ALL videos, no matter that the original format is. But if you start off with a shitty recording quality, it will of course look even worse when processed by Youtube.
i7 2600K @ 4.7GHz/ASUS P8Z68-V Pro/Corsair Vengeance LP 2x4GB @ 1600MHz/EVGA GTX 670 FTW SIG 2/Cooler Master HAF-X
http://www.speedtest.net/my-result/3591491194
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275904
Ok thanks
TheEducatedGamer
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275916
Have a look at this
I have used it for YouTube for all of my videos and it looks just like everyone else's the way you render the video is what matters. You don't upload the H.264 video file that's just silly. Rendering it as a 50,000,000 bit .mp4 however looks incredible.
EDIT: And all other options for screen capture are awful, like Fraps, DXtory and Bandicam.
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275939
You have youtube channel and use shadowplay
Share link and ill see hoe it looks
TheEducatedGamer
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275951
Can you link one of your videos?
https://linustechtips.com/topic/171263-shadowplay/#findComment-2275953
