Hi guys
Was just wondering what would be the best setup, I also have some speakers that I listen to most of my music on.
Wireless:
Corsair Vengance 2100, Blue Snowball Microphone
Wired:
Audio Technica ATH-M30x, Antlion ModMic 4.0
Which would be better for casual gaming/music listening, I am not an audiophile.
I will be doing youtube videos with the microphone and mainly gaming and some music with the headphones. As I said I mainly use my speakers for music but could switch if the M30x's are really good and comfortable.
Thanks
PC: http://au.pcpartpicker.com/user/lbrwnie/saved/4iSW
Laptop: Lenovo Thinkpad Yoga
Phone: Moto X Play 16GB White
https://linustechtips.com/topic/171256-wired-or-wireless/
https://linustechtips.com/topic/171256-wired-or-wireless/#findComment-2275856
Wired but not the M30X plus modmic. Modmic is too expensive to be worthwhile for a $100 budget. Go with Kingston HyperX Headset instead.
Did I mention anything about a budget? I was just asking what set would be better.
https://linustechtips.com/topic/171256-wired-or-wireless/#findComment-2275943
https://linustechtips.com/topic/171256-wired-or-wireless/#findComment-2276144
I've compiled all the prior suggestions for each Wired and Wireless plus my own into these 2 lists:
Wired
  • Better sound quality
  • No Charging
  • Can be slimmer (less hardware for wireless comm)
  • Can play with cable
  • Can have inline volume controls
  • Can be lighter
Wireless
  • NO WIRES
  • Charging
  • Amplifier attached to head
  • Can have onboard controls
  • Heavier
  • Can move around with them (~30ft / ~10m range depending on model)
https://linustechtips.com/topic/171256-wired-or-wireless/#findComment-2276177
Given those two choices, I would just go with the wireless.
If I really wanted quality, it would be a better headphone ( over ear, open, and removable cable... just my pref.).  Combine with mod mic, short mic cable and combine to single cable with headphone.
I have a wired headphone with detachable cable.  Plugs in small wireless adapter (audiomate AM8112) when needed (that's when convenience takes precedence).  Still looking for a good wireless sound and mic adapter so I can use with any headphone/headset.
My Rigs (past and present)
https://linustechtips.com/topic/171256-wired-or-wireless/#findComment-2276179
