Hi guys!
I've got a huge favor to ask? ok first my problem!
I'm quadraplegic C5 since '92 meaning paralyzed from neck down i can use my arms but my fingers are completely paralyzed so here lies my problem...
I can use a mouse and and left click no problems (don't ask me how you just learn stuff you need done) but THE SCROLL WHEEL IS MY BIGGEST CHALLENGE
I need something to scroll with my other hand!!! I remember at my old job we had these Microsoft keyboard with a scroll wheel that was awesome...anyone knows of
anything i can use to scroll especially when coding in Brackets or Photoshop i lose time not using the scroll wheel.
Thank You guys!
and yes i'm a 1 finger (left index) typer  :P
  • CPU: AMD Phenom II X4 955, Chassis/Case: InWin Dragon Rider, Motherboard: Asus M4A89GTD Pro, RAM: Corsair Vengeance 16GB (2x8GB) DDR3 1600MHz, Video Card: Sapphire 7870 XT w/ Boost, Power Supply: Corsair TX750 V2
  • Monitors: 3x Asus MX279H
https://linustechtips.com/topic/171094-i-need-help/
The ergonomic keyboards and some media keyboards have scrollwheel as part of keyboard. Then there are roller-type mouse which have basicly wide bar acting as mouse. Third option would be getting touchmouse and configuring it to be just one big scrolling thing.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/171094-i-need-help/#findComment-2278176
If you have a gaming keyboard set a macro to a mouse function and choose scroll wheel
Thanks I just bought a Corsair K50 hoping it'll work (i'd cross my fingers but i cant) :P
https://linustechtips.com/topic/171094-i-need-help/#findComment-2278494
Dang it  :angry:  there is no options for mouse macros on the K50
https://linustechtips.com/topic/171094-i-need-help/#findComment-2291413
Ok now how would i do that on a K50?
https://linustechtips.com/topic/171094-i-need-help/#findComment-2292454
I have no Corsair experience but here is how to http://www.corsair.com/en-us/raptor-k50-gaming-keyboard click on downloads and download file quote me again after you have done that
Yup i installed all but in the assign key menu there is no option for mouse anything? and thanks for the help!
https://linustechtips.com/topic/171094-i-need-help/#findComment-2293476
here it is:
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294051
i feel sorry for you mate, makes me feel so fortunate,and try maybe moving the mouse wheel to see if it pops up as a selected key in the box
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294144
Advanced Options?
its basic commands it's copy paste select find print save keystroke
advanced command close window lock pc open explorer show desktop launch program
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294148
 even if i click my mouse it only sees keyboard strokes
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294162
Hmmmm
Yup exactly my feelings
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294168
Hmmmm
which keyboard you have that does it?
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294175
I'm borrowing my neighbors and it is an Logitech g510s
shoot i should have asked figured Corsair was a good bet  :(  its the same price as the k50 wonder if ncix would trade  :rolleyes:
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294305
hopefully
nahh they wont :angry:
https://linustechtips.com/topic/171094-i-need-help/#findComment-2294483
Hi PK ...You are positive the G510 has a scroll function on the G keys??
https://linustechtips.com/topic/171094-i-need-help/#findComment-2304035
