Parts compatability
Go to solution Solved by WestcoastPCBuilder,
you can raise the fan up if you want it in a push
This is my build. http://pcpartpicker.com/p/W6crYJ
I have purchased most of the parts except the case and cpu cooler. The RAM is tall and did not expect that it would cause any issues, but apparently it will with the CPU Cooler.  I need recommendation on what to do. I was wanting the hyper 212 evo, which may cause an issue because of the RAM. I am afraid of removing the heatsinks from the RAM. I thought about moving the fan to the other side of the heatsink, though will it cause any airflow issues?
https://linustechtips.com/topic/170818-parts-compatability/
If you only propagate the right most channel you should be fine (i.e. slots 2 and 4).
Just put the fan on the backside of the heatsink in a pull config rather than push
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/170818-parts-compatability/#findComment-2269834
only if you could wait for the 4690k  :P
the cpu cooler will be fine, it wont cause any airflow issues.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/170818-parts-compatability/#findComment-2269835
i3-4170, H81 board, 8GB DDR3, Crucial M4, GTX 770, Xigmatek Vangaurd Case, Creative Titanium X-fi, Razer Carcharias, 500w PSU, 24" VA panel and a 42" IPS. Thinking about getting a plant.
https://linustechtips.com/topic/170818-parts-compatability/#findComment-2269854
