i was just wondering if i can control the RPM on my 140mm fan that is mounted on top of my case. The RPM at the moment is 1473 RPM, the fan is too noisy for my liking and every time i play games, there is only one 120mm fan exhausting the air out, so i assume it gets really hot inside the case. I don't normally connect the 140mm fan because of the noise.
Now, the question is, can i control the fan speed? I have it connected to the 3 pin header on my motherboard. I know there is a program such as SpeedFan, but the problem is, i have no idea how to work it. Does anyone have a guide or tutorial on how to set a fan up so you can control it? That would be highly appreciated.
Thank You.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/170688-fan-speed-control/
Thank You.
http://www.scan.co.uk/products/asetek-fan-speed-controller-kit-3pin-fan-fan-controller-motherboard-kit :)
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/170688-fan-speed-control/#findComment-2268133
OpenHardwareMonitor. Select fan, set speed to it, done. Since its 3pin your options with mobo controlled are 12V/100% or 7V/50%. For lower or something in between you need hardware controller.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/170688-fan-speed-control/#findComment-2271385
i've downloaded the program but it wont let me control the fan speed?
Old Rig
https://linustechtips.com/topic/170688-fan-speed-control/#findComment-2272209
Right click on any of fan control and setup percentage. Note that since they are 3pins you can only have 25%, 50% or 100% as effective and I'm not even sure if 25% would work. Also the fans must be set automatic from BIOS. If you set them manual there it overwrites any software controls.
https://linustechtips.com/topic/170688-fan-speed-control/#findComment-2272298
