Writing this from my phone i turned on my laptop this morning and had to connection.
It does however recognise my internet connection but has the yellow triangle on wired and cabled. I did unintstall and reinstall and also updated the drivers which weren't outdated.
It does say intel wifi technology not enabled so I enabled it and it still don't work. Also says something about wifi adapter but also updated that to. Tried system repair that didn't work and I can't do system restore as there's no previous restore points. I do belive it has something to do with avast antivirus as it came up with error 10013. My computer said avast wasn't the firewall and windows was but couldn't change to avast. I then uninstalled the whole avast antivirus and I'm now with no antivirus as I can't reinstall with no connection. Don't really no what else I can do please help me :'(
https://linustechtips.com/topic/170542-no-internet-connection-help/
This happened to me. Make sure your modem Internet Activity and Cable LED are both blinking or on. if only one of them is on or blinking, unplug and replug the modem until theyre both on or blinking.
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
yh still nothing is working although I've done this many times
Then im out of solution, This problem has been occurring to me when i dont turn on the pc for very long (more than 2 hours, and i usually unplug the pc after im done) and its usually done by that.
(NOW)War Horse:
(WAS)Old Coop:
check internet options and make sure that it's not ticked to use a proxy server in the advanced connection settings.
Aragorn (WS): 250D | 6800k | 840 Pro 512GB | Intel 530 480GB  | Asus X99-M WS | 64GB DDR4 | Corsair HX720i | GTX 1070 | Corsair H115i | Philips BDM4350UC 43" 3840x2160 IPS
Gimli (server):  Node 304 | G4560 | ADATA XPG SX8000 128GB | 2x 5TB WD Red | ASROCK H270M-ITX/AC  | 8GB DDR4 | Seasonic 400FL
 Omega (server):                 Fractal Arc Mini R2 | i3 4130 | 500GB Maxtor | 2TB WD Red : Raid 1 | 3TB Seagate Barracuda | 16GB RAM | Seasonic G-450w
Alpha (WS): 900D | 4770k | GTX 780  | 840 Pro 512GB  | GA-Z87X-OC | Corsair RM 850 | 24GB 2400mhz | Samsung S27B970D 2560x1440
try going into command prompt. ( windows r key then type cmd and hit enter) Type this
ipconfig /renew
then hit and enter and type this
ipconfig /flushdns
then hit enter
Hope this helps.
How ever if the actual internet it down it may be a service outage or your modem is dead.
ipconfig /renew
ipconfig /flushdns
then hit enter
Hope this helps.
everytime I type ipconfig /renew it closes quickly
If this helps I also got a message saying local area connection doesn't have a valid ip configuration
Thats because you are not using your local area connection you are using wifi. It will dissapear because you need to type cmd in the run box and type it in that window not directly into the run box.
You need to access your router's maintenance settings by going into it's lan IP. There should be settings there to refresh the IP and change network settings. You might want to contact your ISP to help you with this though, as it can be quite complicated.
I just did in cmd typed the ipconfig renew that just said no operation can be performed on wireless connection 3 and 2 while it had it's media disconnected
Flushdns just said successfully flushed the DNS resolver cache
