So I posted a few days ago with a problem, I have an Asus H81M-K H81 and a PENTIUM G3240 CPU. The problem could have been just that I needed a BIOS update, so I popped my 4770k in there, updated the BIOS, and while I was at it installed windows no problem at all. BIOS is now 100% updated. I throw the Pentium back in, nothing. Keyboard doesn't even light up. I swapped the 4770 back and it is fine.
So, now I am really confused. I should have put the Pentium in my rig (rig in sig) but I didn't and now I really don't want to swap them out AGAIN. Almost out of AC5 :(
The PC has a single DIM of 1600 RAM, but assuming that could be an issue while the 4770 was in there I set the RAM to 1066. So as it sits, I have a H81M-K with the Pentium G3240 and a single stick of 1600 (that should be trying to run at 1066) and I can't get POST, cant get the keyboard to light up, can't really do anything. Could it actually be a bad CPU, is the RAM just not playing nicely with the CPU? I only have a week before this PC has to be shipped out to my grandmother and I really don't know what to do at this point... Intel RMA might come in time as I can't return it to newegg anymore. Or do I just frikin buy a new CPU that "should" work?
Any advice would be great!
https://linustechtips.com/topic/170330-cpumobo-problem/
Do you have a speaker attached to the motherboard speaker header? If so. what beeps are issued?
https://linustechtips.com/topic/170330-cpumobo-problem/#findComment-2263789
This might be the problem
Max Memory Size (dependent on memory type) 32 GB Memory Types DDR3-1333 # of Memory Channels 2 Max Memory Bandwidth 21.3 GB/s ECC Memory Supported
Yes
My PC
[ I5 4690k (no oc) - Gigabyte Z97 D3H - 8GB Ram - Sapphire R9 280X Vapor-X ]
https://linustechtips.com/topic/170330-cpumobo-problem/#findComment-2263794
No, I dont have an extra piezo might have to pull mine out of my rig.
https://linustechtips.com/topic/170330-cpumobo-problem/#findComment-2263797
Yes
Wouldn't it still boot though? And allow me into the BIOS to change the RAM speed? I only got the 1600 because it was cheaper :/
https://linustechtips.com/topic/170330-cpumobo-problem/#findComment-2263816
Yea about that  i Don't know but you should ask the support of your motherboard's manufacturer for help.
My PC
https://linustechtips.com/topic/170330-cpumobo-problem/#findComment-2263835
