Hello, i am trying to find the best config for my PC, and mine is as shown in my Profile and i have 450W PSU when i calculated with Cooler Master Power Supply Calculator http://coolermaster.outervision.com/ i found out that i need at least 620W PSU and also there is a power surge at my home and my PC restart frequently is there any way that will save my PC actually my PC is somewhere else not using but my secondary PC a low grade one with 250W PSU is restarting because of power surge and i am afriad that my Primary PC will act the same, please help please???
https://linustechtips.com/topic/170097-psu-help-please/
Greetings  @DashAki,
If you may believe you may upgrade your graphics card in the next 6-8months then I would suggest either stick with your current 450w or a 550w with more cable options for your pc.
Of course the essentials that you need are the main 24pin power (20+4), eps 8pin (4+4) etc
Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out.
<| Project M13 & Silverstream. Other DIY projects |>
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2260861
Thank you @wng_kingsley7 & @ForsakenLive for your helps, i will get at least 550W and what should i do with the Power Surge at my home?
When you talk about power surges on your home, do you mean blackouts (when the lights go off) or surges, where unstable currents come vary around different voltages?
Either way, motherboards and PSUs already have electrical protection features, but they still can fail, or ruin a component, if you are sure that this type of problems are in your house (you should measure voltage on the wall plugs) getting a UPS or a Surge Protector might be the best route.
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2264532
@ForsakenLive, i think the current is unstable, my PC restarts when i pug in Water Boiler or any other high voltage devices and my PC keeps restarting unable to fully operate, like when it is showing Windows start screen it again restarts or when showing Starts Windows Normally it restarts, like that and UPS is a little bit difficult for me or what is a Surge Protector?
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2264562
It sounds to me like you aren't able to draw enough wattage from the wall if using any other power hunger devices causes this issue.
A surge protector would cut down on excessive voltage that would potentially fry the computer.
Motherboard: MSI 770-C45 2606Mhz HT 200Mhz Bclk | CPU: AMD Phenom II x4 955 BE 3606Mhz | GPU: ASUS R9 270 DCU2 2GB 1125MHz Core 1500Mhz vRAM
RAM: HyperX Black PC3-12800 1600MHz 9-9-9-20 | Storage: HyperX 3K 120GB SSD SATA II + 570GB| PSU: EVGA 500B 500W
F@H Stats: 7,077,384pts x 576wu (08/14/2015)        green=stock setting     red=above spec     blue=below spec
System Name: Rocinante = "workhorse"
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2264576
For your own safety you should plan on checking the electricity on your place, devices with too little power or too much, can create a fire.
The UPS is simple, you get one that fits your specifications, and plug the system to it.
Surge protectors are extenders with multiple plugs that have a fuse that avoids a high voltage current to reach your devices.
example:  http://www.newegg.com/Product/Product.aspx?Item=9SIA0ZX0TD8626
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2264579
Ok so i get the knowledge that my electric current is not that high, and just fine to operate few devices, and not high enough to operate Water Boiler and PC at the same time, it is low that my PC keeps restarting, so I found out that latest PSUs have Hold Up Time that waits for the current before shutting down. Is my "research" will help me? or i should get UPS?
https://linustechtips.com/topic/170097-psu-help-please/#findComment-2283874
